Currently redoing equipment Pad and wont be able to open for 2-3 weeks.
Just pulled back the mesh cover corner to test. I have a submersible pump to circulate while adding chems. Water looks pretty clear, I can see the shallow end bottom well.
FC: 0
CC: 0
pH: 6.8? (was off the scale yellow for my test)
TA: 20
ca: 10
CYA: 0 (filled the tube without blocking dot, was at 100 at closing, glad to have it down now but worried about ammonia)
How should I proceed? Want to add Cl to prevent algae but worried about pH and TA being so low.
Poolmath says to add 427oz of baking soda, thats a lot.
Last year was new to the house and had pro to open who added Metal Sequestrant among other things, should I do this as well now since pH is low? Not sure if I have Iron issues, stairs were brownish last year, probably organic, but will test with AA.
Thanks in advance
FC: 0
CC: 0
TA: 20
ca: 10
Thanks in advance
