Hi all,
This year has been particularly troubling for our pool, almost as bad as the 2013 year when we had a crazy pink slime invasion that had me 10 minutes from buying a few hundred ton of backfill dirt.
33,000 gallons
FC: been holding at 40-50
CC: 0
CYA: 60
TA: 110
CH: 300
pH: tends to run about 7.2-7.4 normally, FC > 10 so I can't measure right now
Bottom line: I just can't seem to get the pool to go and stay clear this year. It went cloudy earlier this year, in mid-June. It was getting hard to control, and I knew our CYA level was too high from trichlor use (when liquid chlorine was very difficult to find), so we replaced over 1/2 the water and got it down to 60. It was a beautiful, blue color but would never clear up. We are on a well with some iron, but a little bit of sequestrant holds it.
Next step, I replaced our 10 year old sand with new zeolite filter material. While I was cleaning out the filter, I checked the laterals and they look good. It didn't improve anything materially.
I'm in day 7 of a SLAM and it's not getting any clearer. CC is 0, OCLT has passed several nights in a row (0 loss last night), but it's still very, very cloudy. We're brushing all the surfaces and vacuuming daily. Pressure is normal, there's good flow through the filter.
Here's the pool brush in the water. What am I missing here?
33,000 gallons
CC: 0
CYA: 60
TA: 110
CH: 300
