- Mar 17, 2017
- 25
- Vinyl
- Saline Generating Systems Breeze 540
Numbers
pH 7.5 (before slam)
Chlorine 17
CC 2
CH 75
TA 75
CYA 0 to 10 (50 before slam)
Little to no debris on bottom of pool.
First week didn't have much luck, think it was because I wasn't brushing. Back washing wasn't really getting my any nasty stuff in the sight glass. Was keeping chlorine above 17.
Week two I got irritated and started brushing every 4 hours or so (except when asleep). Baskwashing twice a day and getting green and brown stuff in the sight glass. Yay progress. And bumped chlorine up to 20.
Well not making any progress now. I've brought the chlorine as high as 30 and not having any luck. I tested the CYA last night and think it's all gone... Must have backwashed too much?
Pump has been running 24/7 for 2.5 weeks. Water has some yellow cloudyness to it. I don't think my liner is stained... At least I hope not. I let it go green over the winter (from Jan to now). I've been adding de to the skimmer after each backwash. It hasn't been very sunny here lately. My chlorine is still testing high enough, even with no CYA. I'm in the process of ordering more.
Any suggestions why I'm not able to get this last bit of green? Or what's causing the cloudiness?
I've used flocculant and have vacuumed the Grey stuff off the pool floor. So think im doing something right. Just can't get over the last bit here.
26k vinyl in ground
Chlorine 17
CC 2
CH 75
TA 75
26k vinyl in ground
