Hi,
I'm new here, but have some familiarity with pools from a previous property we lived at. We have recently put a new salt-water pool in - 25,000 litres - Halo chlorinator (not sure if this is an Australian brand), pH and chlorine sensors, auto-dose acid, etc. I can’t seem to get the pH down to a ‘normal’ range (7.2 - 7.6) from around 8.2. I've been monitoring chemical levels every couple of days with both liquid drop and test strips and putting a fair bit of acid in on top of the auto-dose.
Total alkalinity ~ 100 by liquid drop. Test strip looks ok. (I am assuming a TA of ~ 100 is ok?)
pH ~ 8 - 8.2 by sensor, liquid drop and test strip.
Chlorine - sensor and liquid drop says ok, test strip says low.
Is a pH of 8 in some pools normal?
Otherwise what else should I do to try and reduce the pH?
Paul
Paul
