Can’t Get Light to Seal
Hackurs
9
Arizona
Hey all, I’ve got a Pentair recessed light in the pool/house we just bought. It had some water in it, but the socket wasn’t bad, no real corrosion. So I bought a new seal, and have tried repeatedly to get the tension ring to fully seal, and no matter what I do, thing never stops leaking. Can anyone assist? What am I missing? It’s not a large leak. Thanks!
Make sure the sealing surfaces are clean. Also check that the sealing face is flat. Are you sure it's leaking through the gasket and not where the cord enters? I have only used Pentair gaskets, if you are using a gasket from someone else maybe it does not fit correctly.
