I've been having issues keeping the chlorine in the pool ever since the water has been reset after 1.5yr of stagnant water and I've never quite experienced this unless I'm not measuring things right. In the past, I used to add less than half a gallon of liquid 10% chlorine daily and that used to do the trick to keep algae at bay. To be clear, I have no algae problems now either, but I'm dumbfounded by the fact that chlorine just doesn't seem to stay in the pool at all. I've measured my CYA and from what I can tell it seems to be somewhere between 50-60 which is rather high for a pool that's treated purely in liquid chlorine. At about 60ppm, chlorine virtually goes back to 0 after adding a half gallon the next day. I tried shocking it and keeping it high for 24hrs and my baseline was to keep it at roughly 3ppm before adding a half gallon per day (ie: in a ~25k gallon pool). Something doesn't add up here for me.
- I don't see any algae which is good, but I'd expect some given the leafs that fall in there and the virtual lack of chlorine in the afternoon
- A high CYA should keep chlorine around a lot longer than this in my experience.
- pH is around 7.6 right now
- This has been going on for a few months weirdly
