Can someone explain what this pipe is?
JimFinn
Active member
Sep 1, 2022
29
Hammond, Louisiana
The previous owner of my house, who also built my pool, told me that when he built the pool, he ran pipes to the spa but never hooked them up. That is the gray pipe in the picture, and I assume the other end is the gray piece next to the eyeball in the spa. There are several of these in the spa. I can't remember what he said this pipe was for, possibly something about aeration. Is that a thing in spas? Currently the spa works just fine when I run it, with jets coming from the sides and the floor jets that can be seen in the picture. He called the floor jets "bubblers", is that a correct term?
Grey is usually for electrical.
It might be for an air button control, which uses small diameter vinyl tubing to carry the air from the button to the air switch.
Maybe a light.
It's not obvious what exactly it was intended to do.
Maybe a light.
Yes, I thought it was a bit strange b/c it appears to be conduit and not PVC. Definitely not a light, the spa already has one. Thanks for your ideas!
