I recently took on my first deep clean of a Hayward S220T sand filter. (I never got to the point of substantially clear water overflowing the opening - calling it done after about 30 mins of gently moving a hose up/down/around).
I also gave the sand a detergent clean, using one of the degreasing compounds. History of this filter/age of sand is not documented.
During reassembly, I found that the multi-port valve could not be seated properly - the vertical pipe between multi-port and laterals assembly was now sitting too high in the filter body. I trimmed some of this thin-walled pipe off until I could obtain a good connection. Now, I find that initial back-pressure during routine filter flow is as low as 3 - 5 PSI. This suggests to me that the water flow is probably now bypassing the intended filtering circuit. Alas, I think I need to unload the filter, reseat a new lateral assembly and start over.
But before I take on this 'punishment repair' I thought I would run it by everyone here. Has anyone else had this issue? And can a lateral assembly really drift upwards a few inches through the surrounding sand, perhaps from spending too much time flushing the sand media with a hose?
