I'm a new pool owner grappling with the car payment sized power bill I got after running my single speed pump excessively last month. I've been doing some research into variable speed pumps, and like what I'm reading about the new Black & Decker pumps. As I understand, the Calimar pump should be the same, with the exception of the housing and included unions.
It looks like my pump has a 2" intake, but the return is only 1.5", so I assume that I'm going to be limited to a max flow of around 44 gpm. I think that running a 1.5 hp Calimar pump at around 1200 rpm will max out my flow. It looks like there may have been a split return at one point, two 1.5" pipes, but one is capped. Also, 2 of 5 jets don't have any flow, so I am assuming this is related. I believe at one point there was a Polaris vacuum that is not longer active, so possible that capped pipe is from that?
So does that make sense? Just get a 1.5 hp instead of the 3 hp and save an extra hundred bucks or so there, since my flow rate will be the main limiter and is well within the lower rpm range of the Calimar?
This is the operating cost breakdown for a 24 hr run time on the Swimming Pool Steve blog using the 1.5 hp pump.
1.5 HP Variable Speed Pump
3 Hours @ 3000 RPM / 86 GPM
6 Hours @ 2000 RPM / 55 GPM
15 Hours @ 1000 RPM / 29 GPM
1040 W/h @ 3000 x 3 = 3.12 kW
348 W/h @ 2000 x 6 = 2.1 kW Watts
68 W/h @ 1000 x 15 = 1.02 kW Watts
6.24 kW per day x $0.13 / kWh
