- May 27, 2021
- 1,380
- Fiberglass
- Pentair Intellichlor IC-40
Hi all, it’s been a while since I’ve posted, been slammed with work. I have a question that’s perplexing me and haven’t been able to find sufficient data from other sources to support my theory so I thought I’d post it up here and let those smarter than me chew the fat and hopefully provide an explanation….or just call me crazy!
-25,000 gallon Pebbletec pool - pebble tech was installed 10 years ago and pebble is in very, very good shape for its age
-Historically chlorinated with trichlor - I just converted it to SWG after some coping and tile work necessitated a fresh drain and refill. The homeowner described his annual issues briefly touched on in the next point, and called me in to balance his water which lead to deeper discussions and ultimately the conversion.
-Homeowner historically “took care” of the water himself with the help of Leslie’s. Always fought mustard algae late in the season due to CYA overdose, and was sold loads of phos free to mask the real issue…CYA levels that were stupid high even by their ”reports”.
-Homeowner never balanced calcium hardness, but did address PH and Alk as best he could with pool store advice.
Prior to conversion I tested the water and made minor adjustments to PH and Alk to bring them to spec. Hardness tested out at 128 ppm. By the math 40 pounds of calcium chloride should raise to 300 ppm target. 4-5 days after the initial dosing when I was testing the water at conversion time the hardness came back at only 178 ppm.
I’ve not seen this before excepting 2 other pebble pools where hardness historically had never been addressed by the homeowner. In each of those cases it took multiple doses over subsequent periods of time and finally calcium reached the desired level, but with a significantly higher volume of calcium chloride than what the math would indicate should be necessary.
So my postulation is that over years of neglect of hardness levels, the water had been leeching calcium from the pool’s surface. Subsequently, when I dosed to achieve appropriate calcium levels in the water, the pool‘s surface that had been having its calcium leeched began leeching the calcium back out of the water. When the surface ultimately reached its desired calcium saturation after leeching it out of the water from multiple additions of calcium, the testing reflected it and no further additions were necessary as I achieved the desired target.
Is this what is actually happening or is there some other issue at play chemistry wise? I can find plenty of data on over saturated water depositing nodules on the surface, but not finding much on the converse where the surface may pull it from the water to satisfy some demand. Thoughts are appreciated.
