- Apr 10, 2018
- 5,212
- Plaster
- CircuPool RJ-45
My father-in-law just completed a 100% drain and refill on a 19K gallon IG plaster pool (non-SWG). I'm helping him to get his water balanced. He tested the fill water with his new TF-100:
FC 0
CC 0
pH 7.8
TA 180
CH 180
We plan on working our way up to a CYA of 40 with Instant Liquid Conditioner, adding bleach, and adjusting pH. My question is regarding CH. Is it necessary to raise CH to the recommended 250+ range. It looks like we can achieve a negative CSI by keeping pH on the low range, which will be necessary anyways to drop the TA. Once TA is in the under 100 range, a pH of 7.6 will result in a CSI of -0.09. I hate to tell him we have to increase CH since that was a contributing factor to the pool draining. He just had his tile media blasted for calcium build-up.
Thank you,
Mike.
FC 0
CC 0
pH 7.8
TA 180
CH 180
Thank you,
Mike.
