Welcome to TFP!!
Please understand, what we teach here is very different form what pool stores "teach". We find that many times pool store employees primary goal is to sell stuff, not necessarily get your pool in perfect condition. As to whether that is because of improper training, lack of knowledge or just to sell stuff I will leave up to you. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their advice and testing.
We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a
TF-100 Test Kit ™. As you will need ot test salt levels, look at the options for Taylor K-1766 Salt Test - For those with salt pools and wanting more precision than the salt strips can provide. The Taylor K-1766 reagents R-0718 and R-0630 come in 0.75 oz size.
I also use a Smart Stir which is a magnetic stirring device that makes testing more accurate.
On the website you can get bundles with all of this stuff in a Pro kit.
While you wait for closing, you have a homework reading assignment. Start with these:
There are several items things every pool owner should know about swimming pool water. We share details on the basics of Pool Water Chemistry.
www.troublefreepool.com
Which should I buy? TFP's recommended pool chemicals are cheap, easy, and won't unbalance your pool water.
Before chlorinating your pool, you should know these simple tips. Learn the best way to add chlorine to your pool.
Please don't go to the pool store for a test kit. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. The
TF-100 Test Kit ™ has this test while very few other kits do. The kits sold at the pool store generally won't won't cut it, but be careful pool store employees are known to say “it's the same thing”. Generally it's not!
So, welcome to TFP!!
