Burned by Cyanuric acid and Calcium Chloride
Nov 18, 2017
42
Atlanta, GA
So, I broke rule number 1 and tried to add chemicals simultaneously. New fill and I wanted to get 20 ppm CYA and 150 ppm CH. I added the 2 together in a sock and threw it in the 450 gal hot tub. 2 min later I checked on it and when I grabbed it, I felt a burning sensation like the water was scalding hot. I let go of it and no lasting effects, but 1.5 hr later and I can still feel it on my hand. It was definitely a chemical burn.
We used the hot tub and it seemed fine, but I would like to know what happened chemically and if I should drain the tub. What was left in the sock definitely wasn't either of the original chemicals and didn't dissolve.
Calcium chloride gets hot when dissolved in water.
Calcium chloride can form into a solid block in water.
You possibly made some calcium cyanurate.
In any case, I don't think that you made anything super toxic or especially dangerous.
Definitely a good example of the rule to never mix chemicals.
Google calcium chloride, look under exothermic process, please never mix any chemicals together again. Want you around to enjoy your hot tub
Me too! I have mixed those chemicals in a thousand times and never noticed anything particular about either.
When the wife suited up, my mind shut down and I thought about balancing the water as quickly as possible. ?. Lesson learned
The heat is expected. There's a reason they market the Calcium stuff as Icemelt.
The rest of it? I don't know. But I want to be in this thread so I get notified when one of the chemist types does answer. @JoyfulNoise, maybe?
Thanks for the quick reply. It wasn't particularly dramatic, but it sure got my attention, especially when you think you might have created new chemicals.
Glad to have a place to go with people who are way smarter than me, willing to help out a stranger. Thanks again.
