- Aug 10, 2017
- 17
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Long time lurker, first time poster- my pool is a well oiled (chlorinated? salted?) machine, all thanks to TFP!
We have the Bullfrog M8 hot tub with ozone generator since May 2022- we love it! We use the tub once a day, twice sometimes.
I change the chlorine cartridge and filter every 4 weeks, as per manufacturer recommendations. I used to set the chlorine cartridge to "2 holes" but even with "1 hole" showing, I run out of chlorine within 3 weeks. With the ozone generator, I did not expect to use up so much chlorine! I have dichlor granules and 10% bleach, so I end up using those to make up the chlorine level. Is this to be expected? If I don't stay on top of it, water gets cloudy quickly, and I had bad algae twice- it took a week each time to get rid of it.
Also- the installer recommended I use SpaGuard Spa Shock-Oxidizer (potassium preroxymonosulfate)- 2 caps once a month. But every time I use it, the tub gets very foamy (even if my levels are spot on). I stopped using it for that reason- is that advisable?
All help is much appreciated
