new here...but i have been using the tfp method since july of last year...this year i added an swg to my 12500 gallon above ground pool which i havent used yet...after opening, i slammed the pool...and then added salt and raised the cya to swg levels...i noticed the brown patches the bottom and did another slam which was difficult due to the high cya of 70...testing was difficult with a fc level of 33... but i did successfully pass the slam test...so i let the fc drift down to 22 and tested again...no overnight fc loss and no cc...but i did see a few new brown patches...so i am assuming the patches are dirt....also found a gritty brown sand in the robo filter...so from here on out i intend to do the overnight test and check for fc loss before i slam...i use bags of shock to raise the fc rapidly and i am suspecting that a some of the powder i am seeing at the bottom of the pool is the "other ingredients" in the pool shock or dirt from the environment
so i guess my question is...is the overnight fc loss test valid at all times or only after a slam...i would hope its valid at all times...if so i wont panic until i actually get testing numbers to validate an algae problem
hi to all and thanks for sharing...i have learned so much here...
