Our MasteSpa LH7 was delivered about 1 month ago. I didn't discover TroubleFreePool until about a week ago.
295 gallons
2 pumps
ozonator
pleatco filter from the dealer
I've read the sticky on maintaining a bromine spa, which has been awesome. We use bromine tablets in a float.
If I maintain between 3 - 8ppm bromine, is there any need to shock the tub? Will the bromine do it's job at those levels or does the bromine need to reach a higher ppm to destroy organic material?
I plan to clean it with some Ahh Some and then purge
The install guys said the grime ring is natural as our bodies detox in the tub the first few weeks.
Does anyone know if Ahh Some contains Methylisothiazolinone or any other Isothiazolinones?
When I drain the hot tub, will the water in internal plumbing come out via gravity or do I need to vacuum/blow them out somehow?
Thank you
295 gallons
2 pumps
ozonator
Thank you
