Based on those results it's probably ok, but you have almost no sanitizer in your water and so it's really not safe from a health perspective to be in there. Disease transmission is highly possible and you probably have an algae bloom that's about to ramp up.
As
@JamesW and I have both said, your pool is very likely over stabilized with too much DMH in it from all the tabs you have been using. Bromine pools are NOT easy to manage and require very careful use and cataloguing of how much solid brominating product is going into it (because there is no chemical test for DMH like there is for CYA in a chlorine pool). It's highly likely that you are going to need to drain a significant amount of that water to get the pool back under control.
AT this point your only option is to switch to chlorinating liquid to activate the bromine and stop using the tabs. When you add chlorine to a pool with bromide ions in it, the bromide gets instantly converted to sanitizing bromine and the chlorine turns into chloride (Cl-). You probably need to shock the pool by raising the total bromine levels up to 20ppm and holding it there as best you can for 24 to 48 hours to see if the levels come back to normal and hold. If the bromine drops from shock level and just goes back to zero or one drop on your test, then there's no way around it, the pool has to be drained.
You're in a very precarious situation and it is not recommended that you let people swim. You have no idea what your sanitizer level is and no way to know for sure if it will hold up while people are swimming. Bromine tends to hide pool problems because it is very good at killing algae off but not necessarily good enough to prevent the transmission of bacterial or viral pathogens. SO the water may look clear and seem safe, but diseases can easily pass (think of kid with a dirty bottom jumping in the water and then all of that fecal matter adding to the pool water...).
It's your call and your pool, but I would get rid of that bromine water as soon as possible.
