I have an above ground pool that had all flexible piping, and I'm replacing with pvc. The guy that assembled our pool used a ton of silicone/caulk to seal all the fittings. When trying to remove the current fitting from the bottom of the skimmer basket, about 1/2" worth of the threaded portion broke off and is stuck on the threads inside the basket. I cannot budge it and I can't get any leverage on it whatsoever due to the flexible nature of the stainless steel panel/skimmer and the weird location of the broken piece.
Does anybody have any tips or things I could try to get this pieece out of here? I started to try to snip it and break it out in pieces, but I don't want to ruin the threads.
Picture attached.. Not the best view but this is from the top down, you can see the little piece stuck on the threads at the bottom.
