Hello,
I drained my 13,000 pool and decided to take off the drain cover to clean the drain out. I was not having any "noticeable" issues with the pool. I just wanted to clean it out before the summer. The drain was really dirty. Lots of leaves, mud, sand that were easy to scoop out. One of the drain pipes/holes is completely filled with mud and sand. This would be the drain hole at the top of the picture. I put a stick in it and the mud is fairly compacted in there.
What is the purpose of the three different drain pipes? Is the mud and sand normal? Will it fix itself once the pool is refilled and the filter starts running? Or do I need to call someone to vacuum this up (or is there some other fix)?
Thank you so much for reading and any suggestions.
