If the water is from a well and it has an “earthy” smell it is likely humic and fulvic acids (complex organic acids) that come from the decay and breakdown of organic materials (compost). It’s indicative of shallow wells or a well that might have a compromised well casing.
Have you had the well water tested by an independent lab?
Was the condition of the well certified when you bought the home?
my state (NJ) requires a test of the well water which was performed, but it's not very helpful. They are more looking for contaminates, my water failed a new test for PFAS and the seller had to install some big resin $7k tanks (with a big blue 20 inch pre and post filter) to remove it (at the cost of the tax payer, it was reimbursed by the state). However, they dont test for humic and fulvic and didnt even test for sediment and sand.
I added 2 outdoor hose bibs that bypass their system (so i am not wasting the filtration to wash my car, etc and to avoid the pressure/flow restriction) and boy is it bad. I got tons of sediment in my spa. (See picture, that is just from running t he spigot into a bucket for 3 seconds after sitting). Unfortunately none of that was caught. I am sure I should have had a well company come out and test the well but there are so many things to check when you buy a house you cant possibly get every inspection possible done. Like I paid an extra $800 for a full septic test but did not test the well, i assumed the water test was sufficient.
I don't know if I just need a twist and clean filter (or spin down filter) or I need to have a well pro come out and check the well itself. I've been trying to find someone who does both water treatment AND well maintenance. my fear is that if I get a well company they are going to recommend a new well or some major work to my well when maybe all I need is the twist and clean filter.
No idea if the sediment is part of the smell issue, but I wouldnt be surprised.
I dont think my well is shallow but I guess it's possible, my neighbor across the street is 150ft deep, I would imagine mine is similar since it's a development built at the same time. I am in a rocky mountainside (a small mountainside lol, it's northern nj after all lol) though so it might just be the conditions of the area..
I've attached my well report, maybe something helpful there... I guess I need to find a company who tests for humic and fulvic?
Thanks for your help!
