It's a siphon, where you fill the whole hose up underwater then cover one end with your hand and move it out of the pool below the pool's water surface. Works really good, just keep an eye on it because as Bama says, it can move a lot of water.
Do you have a main drain? You could pump to waste from there.
If you don't have a main drain and you cant get your siphon hose below your pool surface, then a cover pump/submersible pump will work.
Do you know how high your water table is? Plaster pools can float up (pop) due to ground water being too high, once they have been drained part way.
