Maybe @chem geek or @JoyfulNoise can chime in, but I'm wondering if something in the water can produce a false positive on the BTB/Xylitol drop test. I've either got ~30ppm in my fill water or something in my water is causing the test to read high.
Source water is:
ph 7.2-7.4
CH 500-600
TA 250
FE... Lots
MN... 1-2ppm
CU 0
H2S present in unknown quantity.
The reason I'm asking is, the number appears do drop after going through greensand reduction and an ion exchange resin, neither of which should lower the borate significantly to my knowledge.
What else could be going on?
Source water is:
ph 7.2-7.4
CH 500-600
TA 250
FE... Lots
MN... 1-2ppm
CU 0
