Hi all. I have a DE separation tank that had some cracks and ultimately, has two lip pieces broken off at the top of the plastic tank where the lid connects. As such, there is now no seal on the lid as the tank o-ring doesn’t sit against anything so is useless.
I had tried in the past to repair with putty and super glue but ultimately, the whole thing blew apart from the backwash pressure. Because this is a separation tank, I don’t use it very often except at start up for backwashing the DE filter and then the occasional backwash during the pool season. I don’t have anywhere to run a hose to run on waste so the plumbing from the tank goes back into the pool after filtering through the separation tank bag.
Problem is because of the broken lips, a large quantity of water splashes everywhere and it’s a mess whenever I have to backwash. Water shoots everywhere and quite a bit of water gathers against the side of the house and risks infiltrating into the house.
A new tank is prohibitively expensive because this is an older unit. I wondered if a repair and formation of a new “lip” at the top of the tank would work and hold up to the backwash pressure without imploding?
Would bondo work? (I have no experience with this but just assume I’d mold and sand). Aside from bondo (like what is used for cars?), does anyone else have any additional advice on repair?
