Bonding new pool questions
Jun 5, 2017
15
Rippey, Iowa
Getting ready to bond my all resin pool. I live in the country and have no codes or inspector to deal with but still want to do this right and only once!! My plan is bury 8 gauge solid bare copper wire around the the pool and connect it to itself with split bolt connector. Then I plan on coming off my "halo" with individual jumper wires to the skimmer, wall, pump and SWG. Anyone see a problem with this or suggestions on how to do it different?? I've read some posts where inspectors want a single run with it all looped together with no connections but can't really grasp how to do this. Thanks
I believe you need one piece wire all around the pool and then you get the special wire connections from Lowe's or Home Depot to join the others. Should be 4 equally spaced to the pool wall. Search for Mike Holts latest code.
A split bolt connector is approved and acceptable you don't need one continuous piece of wire.
You sketch looks fine only thing I would say is just run one wire to the equipment pad and just grab the pump and SWG on the same wire.
