I have a recently built gunite pool with raised spa. The spa has 2 spillovers that are currently tiled inside with no lip. The spillway water has a nice arc, but also dribbles and saturates the stone face of the spa.
Now I’d like to buy and install copper spillway scuppers to better sheet the water and keep it from running back and saturating the stone wall.
The problem is that I can’t easily bond new metal scuppers since the pool is already built and the bonding wire is buried beneath pavers, etc. The pool was properly bonded when built (rebar tied to equipment, etc. with copper wire and bonding lugs) but it is now inaccessible.
So, since the pool shell and the water running over the spillway is already bonded, do I REALLY need to bond the scuppers? How much risk is there if this is the only unbonded metal item?
Current spillway:
Desired metal scupper insert:
Current spillway:
