Hello Everyone
New to this forum and fairly new to pool ownership. I have a pool issue which I need some advice on.
We have a salt water pool built in 2017 with Pentair equipment and I have weekly pool maintenance.
My regular pool tech was out sick and someone else came by. After they did, we noticed a lot of blue crystals in the bottom of the spa (see picture) and in the pool itself. Spa water was kind of cloudy. We had never seen this before.
We cleaned some of it out with our pool vac and asked our regular pool tech to clean the rest when he returned the following week (there was a lot in the pool and it did not dissolve for quite some days). Whatever the crystal was there was enough of it at the bottom of the pool that the following week he scooped it out and threw it on the ground by the spa.
Shortly thereafter we started noticing black staining at the bottom of the pool, especially in the areas where the blue crystals had gathered (see pictures). Our pool tech says he has scrubbed the bottom of the pool but it is not coming up (so probably not algae). My tech also replaced the pool filter (which was only 3 months old) and it was also stained blue.
I am no pool expert...a google search leads me to believe that the blue crystal was copper sulfate and the black staining is a result of the excess copper sulfate in the pool. But I am certainly open to other suggestions as to the cause.
I have told this to the owner of the pool maintenance company and he says that they don't use copper sulfate. He thinks the staining could be from copper piping the heat pump reacting with the salt water. He doesn't explain why the crystals and then the staining all appeared within a week or so. He is offering to clean the pool (acid wash) and says that installing a bypass filter so the water doesn't run though the heat pump in the summer when we don't heat the pool may help.
I don't really believe in coincidences so the fact that we saw all of these blue crystals in the pool shortly after a replacement pool tech came by make me think he added something to the water that caused this. But I don't know enough about pool chemistry and equipment to rule out some interaction with copper in the heat pump that suddenly (in the span of a few days) caused staining and left a lot of bluish crystals in my pool.
Any suggestions (and let me know if you need more info)
Thanks!
Thanks!
