- May 7, 2021
- 161
- Plaster
- Pentair Intellichlor IC-60
Last year I had the waterfall line from the drain blown out with an airlock for winter. This is the right most pump in the attached picture. I kept the bubblers running with freeze protection on. With the equipment below the pool level, is it necessary to blow out the waterfall plumbing? With the water intake from the pool drain off could I just drain the waterfall line out the pump and close it up? I know there would still be water in the pipe leading up to the shutoff valve.
And same question for the bubblers, but I know that's a different situation with the bubblers being about 6 inches underwater on a ledge.
Thanks.
Thanks.
