First year closing my pool - here's what I've done. Looking for help on blowing out lines.
Pools is vinyl, 1 skimmer, 1 main drain in deep end, 2 returns. Hayward sand filter, Hayward pump, Hayward HeatPro heat pump
Day before closing
-Balanced chemicals (PH was high)
-Added a bunch of clorox - probably to about 12 PPM
-FC ~12, CC - 0, CYA - 30, TA - 80, CH - 150
Closing day
-checked FC - negligible overnight loss
-pulled out ladder
-disconnected pump (stored in garage for winter)
-connected shopvac to return lines - blew out both, plugged returns
-disconnect shopvac, added antifreeze to return, realized antifreeze was stuck in heater isolation loop
-tried to shopvac the antifreeze further into the line, hose blew off and antifreeze sprays everywhere, oops
-opened returns slightly, turned shopvac back on, blew lines until a little anti freeze came out, replugged lines.
-put gizmo in the skimmer, connected shopvac to intake lines, blew out skimmer line, plugged gizmo once mist was very fine (do i add antifreeze through gizmo blow out valve?)
-tried to blow out main drain with shopvac - FAIL. I know it's moving some water, because i can hear it refilling the line
-went to lowes, bought a 2 gallon 300 psi pancake air compressor
-tried to duct tape air compressor to main drain line - it blows out the main drain but loses pressure to fast because, well, duct tape isn't air tight.
-give up for the day.
My questions:
-I learned I can hook the air compressor directly into the pump drain - so i'll have to reconnect the pump. But if I do it this way, how would I go about adding antifreeze?
-Is the method i used to get antifreeze into the returns okay? do i need to do anything further to them?
-with the gizmo, i wasnt planning on lower the water level - is this correct?
-I bought a winterizing pill with good reviews on amazon - can i just follow the directions on the box? usually pros add algecide, is that needed?
Any tips overall? Is my process overall pretty good?
Thanks guys!
Day before closing
Closing day
-pulled out ladder
My questions:
Thanks guys!
