Hi all, I recently bought a home with a gunite pool/spa with a small spillway between the two. The pool is probably 1980’s vintage, but no one is quite sure how long its been there. One of the things Im trying to troubleshoot is the blower. It looks original and sounds like a jet engine, but the thing seems to be working fine. The spa its pumping air into is a half circle smaller spa. It has three wall jets, the center one seems to get most of the flow when the return valve is set to spa, but the other two get some water flow as well.
There are 6-10 floor bubblers and when the blower is on, a considerable amount of air comes out of them. The 3 wall jets dont have any air coming out of them however, just the return water pressure from the main filter pump. There is an upside down p-trap style air vent close to the blower, but nothing is coming into or out of this vent when the blower is on so Im not sure what its purpose is (see photo). The 3 spa jets are female threaded ports but dont currently have anything screwed into them. They have small orifices inside them and seem like some kind of venturi jet, but there are no venturi valves adjacent to the spa or anywhere at the pool pad. The spa is 15 or so feet from the equipment pad and no Hartford loop anywhere I can see. Most of the plumbing is completely encased under concrete. There is a small older sprinkler valve (see photo) an inch from the blower, but I am not sure what its purpose is either. Opening/closing the valve seems to do nothing whether the blower is on or off.
- How can I tell if the spa was designed to be a floor bubbler only or if there is supposed to be air coming out of the jets?
- Any things I can try to get the jets working if so?
