Hi all,
I could use some help with our pool issues. It appears we have black algae and I believe I understand the SLAM process, but in light of my apparent CH problem, I am at a loss as to where to start and in what order to address our issues.
Here are my first try at test results with the K-2006 test kit. I ran them in duplicate. Just for reference and in the interest of full disclosure, I ran water over to the local Leslie's (used over the last five years until now - results are as of 8/5)
FC = 1.8, 2.0 (first method was .2ppm per drop, second was 0.5ppm per drop) -- L 0.92
CC = 1.8, 2.0 -- L 1.19
pH = 8+, 8+ -- L 8.1
TA = 80, 80 (a very pale red after 7 drops in both cases) -- L 68
CH = 950, 875 -- L 491
CYA = <30, <30 -- L 15
Salt (if applicable) = Cell indicates low salt. -- L 3488
The CH test was the main reason I ran everything twice. I wasn't sure I was doing it correctly (35 and 38 drops with the 10 mL sample volume method).
My wife attempted to scrub the algae, but was only able to remove the surface, consistent with what's been described here.
I haven't delved into the operation of the SWG, thinking I'd do that as I addressed other issues.
One of the attached pictures shows white material sitting on the bottom of the pool. Is that salt or some other material?
Any assistance you can provide to get us back on track is greatly appreciated. I just don't know the order in which these issues should be addressed. I am picking up a stainless steel brush and liquid chlorine this morning and will pick up other needed supplies as suggested. Do I need to bring up my CYA first, so is stabilizer on the list as well?
Thanks for you help,
Keith
Keith
