- Jun 18, 2019
- 594
- Plaster
- Pentair Intellichlor IC-60
I went swimming last night in a perfectly clean pool. At sunrise, I went down to check chemicals and found tons of brown seed like things. Also were two dark streaks on the plaster. I was able to scoop up many seeds with the net, but when I hit the streaks with my pool brush, nothing happened. I then entered the pool and scrubbed with my steel bristle brush. I got it a bit better, but I can't get rid of all of it. I ran out of time and had to get to work for a meeting. I'll hit it with pumice tonight, weather permitting.
I did find one piece of feces which I also pictured. Strangely that's all I found, everything else was seeds (coffee bean sized). I do not think this is mammal given it's the dead center of the pool and no signs of any activity towards the walls, steps, sides; amazing dead center hit. The streaks and debris field leave me to believe this was an aerial bombing with forward momentum. The loose stuff first, which hit in a pattern and maybe rolled downhill a bit, then the undigested seeds were further down the pool. I didn't spot anything on my cameras, but I believe it happened in pitch black so nothing it could've picked up on. I did see a raccoon on my deck, but I see that guy on my cameras every morning, and he wasn't wet and he was leaving the area of the pool. As stated, that guy's a known quantity and walks across my deck and terrorizes my neighbors front yard
The robot was NOT in the pool while this occurred so it is not the treads from that. I did manually collect and net many of the seeds and the robot had no issue picking up the rest swiftly, but there were a lot. Regrettably, I didn't take a picture of the initial carnage, but it was the two steaks and copious seeds, and then the one liquidy poopy organic matter I showed.
Any tips? I'm going to use the Pool Cleaner pumice thingy and get my scuba weight belt to really scrub it hard (was hard this morning as I kept floating to the top). I'm also bring FC up, dumped a bottle in and running Super Chlorinate. I'm planning a filter clean on Sunday anyways, but would like to get as much of this out as possible
