I just thought I'd follow up on the entire process. I have really learned a great deal since the initial fill and given the chance to go through the process again, I would make a few changes.
The 500 -TA - CH formula works well for the initial amount of Bicarbonate to add but past that point, I'd just shoot for a CSI of +0.6-0.7. With as quickly as the pH rises from the TA being so elevated, I would want to limit any possible chance of scale (especially in brand new plaster). In my situation, this meant checking the TA and pH twice daily and adding nearly a gallon of acid (pH maintained between 7.8 and 8.0) per day. On average, my pH would rise 0.15- 0.25 per day, and that was with as little aeration as possible (I ran the spillway at a trickle with the air vent closed).
I now wish that I would have never added any calcium to the pool. I was so focused on getting the TA and CH into the RECOMMENDED levels that I added enough calcium chloride to get my CSI to -0.4 which at that time equated to 375 ppm. In hind sight, I would have kept the pH and TA higher (to compensate for the low CH) and adjusted both downward as the CH naturally rose. I would have also been much less aggressive in lowering the TA and allowed it to drop on its own with frequent acid additions.
My pool has a very large surface area in comparison to the volume of water it contains. That, coupled with high amounts of evaporation (84"/yr. per Chem Geek's post), my CH is rising at an alarming rate. My current CH is at 575 and i suspect it will be near 650 by the time things cool off. I might be able to make it one more year before I need to do a partial drain. Had I held off in adding the calcium and maintained a higher TA, I could have bought myself a little more time before a drain was required. I understand I would have had a higher acid consumption, but it really would have only been for a few months.
What I found surprising (after lowering the TA) is that my CSI was difficult to keep above -0.4 (TA 60-70) until my CH rose to 500 (I have a SW pool and use 50 ppm of borates), I now maintain a CSI between -0.3 and -0.1. Once the CSI reaches -0.1, I lower it to -0.35. Once it comes time to lower the CH, I will more than likely aim for no less than 450 ppm.
Lastly, I should have been adamant with my plaster contractor about not adding any calcium to the plaster mix. I was able to get him to drop the quantity in half, but even that was a fight. Calcium is used to shorten the time it takes to finish the plaster, but really all that it produces are color variations and a surface with areas that are noticeably rougher (set up too quickly). The additional calcium provides no benefit to the longevity of the plaster, and although I am unsure of it, I would imagine that the increased amounts of calcium in the plaster would be that much more detrimental to its integrity during an acid start up.
For the most part, the process was painless. I had no prior experience with water chemistry which leads me to believe if I could do it, then anyone can. The plaster is a considerable investment, why not take matters into your own hands to ensure its longevity?
