tcat
- May 30, 2012
- 1,783
- Plaster
- CircuPool Edge-40
Oh - I have been reading it a lot. I think I give another couple of months but keep updating the thread with any data.Check out my thread on the Aiper Scuba S1. Really starting to enjoy it.
I just took a piece of 1" foam I had laying around, cut it to make a divider that sticks out a little. It seems to steer away from it. Or you can turn skimmer flow down a little if your skimmers have a separate valve. You barely need them if you run Betta 24/7.Got the SE Plus and it was hung up in skimmer current within 5 minutes. Not enough power to pull away from it and I’m only running the pump on a medium speed. Don’t want to turn down the pump or put barriers around the skimmers because they do a fantastic job. Was hoping to just help them out with the Betta. Bye bye Betta.
I’m very happy with ours.The SE Plus is now on sale on Amazon for $359. I'm thinking of pulling the trigger. Worth it?
It's worth $500, so yes.Yes, and go back and buy the 3 year extended warranty.
Tell us if you purchased it. Did you purchase the warranty separately from Betta directly?The SE Plus is now on sale on Amazon for $359. I'm thinking of pulling the trigger. Worth it?
It depends on my water level. Mine is definitely not 8" deep unless maybe my pool is totally full. You'll be fine!DB how shallow is your splash pad? Mine is around 8" deep and I'd hate for it not to be able to get that area (8' x 20').
Just ordered the Betta SE- Plus from Amazon on Tues night and am sitting on my front porch annxiously awaiting the delivery truck. Betta said I could buy the warranty from them regardless of where I bought it so I went with Amazon since the return policy is sooo much easier. And it was the same price from both.I just emailed with Betta. It was $30 cheaper on Amazon. They said I could still buy the Betta warranty even though my purchase was on Amazon. I’ll give it a go!
Great.Just ordered the Betta SE- Plus from Amazon on Tues night and am sitting on my front porch annxiously awaiting the delivery truck. Betta said I could buy the warranty from them regardless of where I bought it so I went with Amazon since the return policy is sooo much easier. And it was the same price from both.
Can’t wait to use it in conjunction with my Aiper Scuba S-1 which I’ve used every other day since I got it and am pleased with its performance in the floor only mode. Only did the walls once and it got about 70% coverage so it’s time to try it again to see how it does. Pereonslly, since it’s getting 98% or more of the floor, I’m happy since that’s where all the dirt is anyway, so I won’t be sending it back. I’m expecting to be even happier with the Betta since my dogwood is dropping all the flowers in my pool today. Fingers crossed.
Mine works fine over my shelf. There's a little step down to it where it has gotten hung up but Betta sent me a longer set of anti-stranding legs which has taken care of that.Anyone have experience if SE plus works with baja shelf?
edit: it's working fine over the shelf, water depth is more than 3.5" so all good.
Used unit that you can purchase through the website are from our customers who return the unit within they're 30 days warranty period.
Theses units are 100% working and passed through our quality assurance team.
It also comes with a standard warranty of 1 year, like the new ones.
You can also purchase the extended warranty for the used unit.
With some time I’ve noticed that no matter which set of legs I use, and at what position, unless the water level is at the top of the skimmer door it gets stuck on something - the Baja shelf, the step to the shelf, or one of the 3 corner steps. I ordered an aftermarket set of legs which is a little longer. We’ll see. If I can’t leave it without it getting stuck it will go back.Mine works fine over my shelf. There's a little step down to it where it has gotten hung up but Betta sent me a longer set of anti-stranding legs which has taken care of that.
