Hello everyone. I covered and plugged the inlets and returns from my Bestway 18' above ground pool back in September (live in upstate NY) and removed the filter, pump and all lines leading to these inlets and returns. There have been no issues with this until this morning. I went outside and heard what sounded like a faucet running. Sure enough, upon checking, I saw water coming out of the port (it's the one port of the 3 on the furthest right side if you're looking at the pool straight on) as if there wasn't a plug in that inlet to begin with. I should also add that the last few days the weather has been exceptionally mild with temperatures in the mid to upper 50's after weeks of below freezing temperatures. Fortunately I had an extra "Lincoln style" plug which I used to plug the opening at the outside of the pool to stop the leak. Unfortunately, I can't get to the inside of the pool as there is a thick layer of ice at the top and I'm a little concerned about incurring any damage to the pool if I start breaking up the ice at the top. Feeling inside the port hole with my fingers, I can feel the plug inside the pool that I put there back in September and it now feels loose after being snug back then. Has anyone run across this before and is my only remedy at this point to leave the Lincoln plug in on the outside until spring when the ice starts to melt or should I get one of those rubberized plugs with the threaded T-handle (link attached) and put that in the outside part of the port? I think I got to the leak before a lot of water drained out as it was fine the night before this morning. Thank you in advance.
