Just added salt to pool yesterday. About to start SWG running today. What's the best way to shock or boost the pool to start getting levels where they need to be? And when do I add CYA?
Can I not run the "boost" cycle on the SWG? To increase the FC levels?
So with about 10,500 gallons how much bleach is needed to boost it?? I will check my FC when I get home shortly.Can I not run the "boost" cycle on the SWG? To increase the FC levels?
The needed FC level is based on your CYA level. Typically around 6ppm.
Then use PoolMath to get the needed FC.
6ppm is 93 oz (about 3 quarts) of 8.25% bleach.
So if your FC is 0, then add 3 quarts of bleach. Try PoolMath with your numbers.
SWGs have a finite life in # of hours. Using bleach is much easier and faster.
I'm just saying to add bleach to get your FC up to the proper level. Then turn on the SWG.
Are you in the SLAM process? Why did you go to "shock" level?
If you are slamming then turn your SWG off and use only liquid chlorine to SLAM. The SWG cannot produce chlorine fast enough for the SLAM process and you wouldn't want to put that kind of load on the SWG.
On the other hand if your water is beautiful and you just want to start using the SWG, then you don't need to be at slam levels for chlorine. Use the FC level in Recommended Levels article and Chlorine/CYA Chart in PoolSchool.
In that case use the bleach to raise the FC. Do an OCLT. Assuming you pass, let FC drift down to regular level, then start the SWG.
OCLT=
Overnight
Loss
Test
Chlorine gets consumed by two things basically. Organics in your pool and sunlight. By checking your FC after sunset and just before sunrise you can see if you're losing chlorine to organics (algae) but not sunlight. Little (less than 1 ppm) loss on the OCLT pretty much rules out algae.
Now....with that said, you'd want to ideally keep your pump running but your SWG off. The OCLT is pointless if running a SWG that is producing chlorine overnight.
