Hi all,
Long time lurker, first time poster. Thanks also to the devs of the pool math app I am loving not having to schlep down to Leslies and taking my own measurements with my Taylor kit is super easy. I am a first time pool owner and the previous had let some spots of algea develop, I suspect due to low chlorine levels when I started testing. I have been brushing these with wire brushes and they refuse to come up. The only thing I found that worked on one of the spots was taking a chlorine tablet and rubbing the spot with it (picture with the red circle). Any other strategies so I dont have to dive down in the pool and do the same on the other spots in the deeper end? If I brush with a wire and SLAM will that work? I have brushed and then shocked to no avail and it seems that some come up while others dont. Looking for the best way to address.
Latest chemistry:
4.0 FC
0.2 CC
7.7 pH
90 ppm TA
360 ppm CH
55 ppm CYA
0.22 CSI
88 degrees
Latest chemistry:
4.0 FC
0.2 CC
7.7 pH
90 ppm TA
360 ppm CH
55 ppm CYA
0.22 CSI
88 degrees
