You can plug the skimmer and then fill the line with water.
If you have a check valve at the discharge of the pump, then the pump will stay primed when you unplug the skimmer.
You can even add a hose bib to the discharge of the pump before the check valve to allow you to fill the entire system with water before starting the pump.
Plug the skimmer, connect a garden hose to the hose bib, open the hose bib, turn on the hose until the water is coming out of the returns, close the hose bib, unplug the skimmer, start the pump.
You can remove the pump lid to fill the suction if necessary.
Hose pressure is really high and can damage system components if the water has nowhere to go.
So, be careful not to pressurize the system with the hose by leaving a valve closed.
If you get a single speed pump, and your suction lines are 1.5", the pump will probably cavitate.
