Hello,
Greetings from the great white north...
We recently renovated our yard and ended up relocating our pump and filter. We have an inground pool, approximately 14x32, holding about 25,000 gallons.
The pump is now located 50 feet from the pool, but more importantly a good 15 feet above the pool level.
The suction tubing runs relatively straight from the pool to the pump at a gradual incline. No sharp turns, angles, elbows, etcc.
The pump I currently have is not able to prime and start the water flowing no matter what I try. Lines are clean an not blocked in any way. By forcing a water hose into the skimmer line I do eventually get a small trickle of water to flow but not enough to get suction from the bottom drain and create a full vacuum.
Question I have is there a pump capable of providing enough suction lift for my configuration and how can I tell before buying.
HP and GPM are not sufficient I believe.
Any help, recommendations would be appreciated.
