- Oct 21, 2020
- 12
Hi everyone,
I have a pool company in Louisiana and have recently started implementing TFP methodology rather than buying all kinds of specialty chemicals from Leslie’s and it has been working great! I’ve used it to clean 7 swampy green pools to crystal clear. Several of those customers have requested my services for weekly pool maintenance now. Typically I use cal hypo powder to maintain free chlorine levels at 5ppm. After reading many threads on the forum, I’m curious to what y’all typically use for chlorine maintenance.
Tri-Chloe tablets are what the pool store I’m partnered with suggests but obviously this has resulted in high stabilizer levels for many customers. Lately, I’ve been using cal hypo shock treatments once a week to keep chlorine levels at a preventative level but now I’m aware that it can lead to calcium stability problems. Is sodium hypo in bleach form the preferred maintenance chemical? If so, how can I use it in a cost effective way to prevent transferring the cost to clients? Is there an automatic/ trickle feeding system that I can use to produce a steady stream of chlorine injection, similar to chlorine tablet feeders?
I appreciate the time and advice y’all provide and, please, mention factors and issues that I may be overlooking.
