red-beard
- May 27, 2019
- 1,621
- Plaster
- Hayward Aqua Rite Pro (T-15)
So according to my Pool Math logs - from May 1st to Oct 31, I used 30 gals of LC (some was at 10% and some at 12.5%) - so that is roughly 5 gals a month which seems low, however my CYA was running a little high at 80 so once I got my FC level up, it was easy to keep it there. Also, I did make small (3-4 day) trips to see family and I did use tablets during that time (which is why my CYA was running high). In looking back, in August, I was using 24-32 oz of LC per day. Not sure all of this makes sense but I tried to keep my Pool Math logs current so I believe the data is fairly accurate. Right now, my CYA is low (at 40) and currently using 16-24 oz every couple of days. But my CYA will come up in time because of use of pucks when I visit family.Just curious...I've tried the liquid Chlorine here in Houston/Katy area like you and during the summer it just seems I can't maintain proper levels. So for the past few years I've used liquid during winter and spring and tablets rest of the year. I prefer to switch full time to liquid chlorine, so curious ...to maintain proper levels during the hot summers in Houston... is this pouring like a half gallon or a gallon every day to maintain levels? This seems like a hassle, costly and I'm sure would also damage a few items of clothing...LOL. Just curious how you routine looks like in the summer months. Thank You
If I were a betting man, I would put money on no BOGO this year since we are close to the time when it normally starts and it appears that the 11% will continue through the period that it is normally advertised.Menards Hamilton OH net 2.99/gal after rebate, sale started wed.; 12.5%; date code 21098
bogo or no bogo this year??
im down in auburn, ky which is about a little over an hr from the nearest Menards (Owensboro). Id like to purchase quite a bit since my local dealer has 10% for $4ish. How long is stored in my garage would you recommend storing 12.5%? if its only a month it probably wouldnt be economical to make the trip but if i can buy a whole years worth it would. thanksMenards Florence KY, Cincinnati area $3.99/gal 12.5%, 21090 date code, current 11% rebate net 3.55, had at least 20 cases of 4 gallons. 4/18
Most here "poo poo" cal-hyp powder. In 50kb containers it is about $3/lb, delivered. It does not go bad over time. Yes, it raises CH, but not like CYA. And it is a lot less messy than LC.im down in auburn, ky which is about a little over an hr from the nearest Menards (Owensboro). Id like to purchase quite a bit since my local dealer has 10% for $4ish. How long is stored in my garage would you recommend storing 12.5%? if its only a month it probably wouldnt be economical to make the trip but if i can buy a whole years worth it would. thanks
None of those are recommended here.Hello! cn you recommend me a pool chlorine, please? I found these article, but i just got a pool, so i don't know about this anything)
Suggest you search for NAPCO store. The one in Houston (Spring, TX area) sells to the public 3 days a week in 5gal containers. This is the best bulk store I have found.Anyone know where to get Bulk LC in the DFW area, preferably the Ft Worth side? Maybe going in on a bulk purchase as a group?
