It looks like the granuals also add a form of borates and maybe even more stabalizer? ( the 22.2%) The borates wouldn't be bad, but adding more stabalizer (if that is what it is), would speed up how fast you would need to do water changes. Take a look at the "dichlor then bleach" method for hot tubs here: http://www.troublefreepool.com/how-do-i-use-chlorine-in-my-spa-or-pool-t10095.html. Using trichlor verses dichlor is similar, though the dichlor adds more cya per ppm of FC. Trichlor does lower ph more than dichlor per ppm of FC.
