I just installed my pump and was following all the instructions just fine until I got to backwash.
The step prior to backwash it says to open the valves (the two for the hoses going to the pool) and let the water get rid off all the air.
Then when it says you see the air gone (which I did) to close the valves to finger tight, so I did.
The next part is to do the backwash and I am following the instructions but it never says to open either valve before doing the backwash.
Doesn't one or both of the valves need to be open to do the backwash so it can actually get water?
I can't believe they tell you to close them then the very next step is to backwash and they don't say anything about opening them back up, so I wanted to clarify before I did anything.
Thank you.
Thank you.
