Hello all. I was here on June 7th with some questions about testing my own water instead of the pool store. The advice I got here was to add liquid bleach to reach about a 6 of FC. I still don't understand why, but I trust you guys, so there's that . Anyway, My pool was clear already before then (and still is) looking amazing and clear but I still wanted to test my own water to get the experience and learn. These were my readings back in June when I came here to learn about what this all means:
FC: 2.25
CC: 1
CH: 275
TA: 140
CYA: 45
Salt: 3200
So that was in the beginning of June. I had added some Lo N Slow, and also added some liquid bleach 10% to bring the chlorine to a 6, as I was advised in these forums to do. All was well as far as I was aware and I tested a couple more times and it seemed fine I guess but I really don't understand what my numbers should be I guess, but pool looked good so kinda ignored it for the most part.
I like to keep my salt at 3200 and since that time in June, the salt went down to 2900 a few weeks after coming to you on the forum here, so I added 2 bags of salt to bring it back up to 3200, and also turned my salt cell to 90% and started running my pump 11-12 hours a day instead of the 9 hours a day I was running it before. OK, Now...
Fast forward to about 6 weeks later after adding those 2 bags of salt, my salt is back down but even lower, it's at 2500. I haven't tested the water in a few weeks so I tested it today. Here are my readings:
FC: 4
CC: 0
TA: 140
CYA: 35
Salt: 2500
Can anyone translate this to english? Why do I have zero CC? Is it ok to have zero CC and is that a good thing or a bad thing? I don't even know what CC does, lol, I just know I had a level of at least 1 CC every time I've checked it until today.
Anyway, I guess I'm also wondering is it normal to need to keep adding salt in the summer? The pool was built in January so it's brand new. I've only added salt once so far, in June, those 2 bags. Now I will need to add more, probably 3.5 bags. I haven't been to the pool store yet to get it. Also my CYA is 35, isn't that too low?? It's always been high
Someone on a FB group said you shouldn't be losing salt or else something is wrong, so that kinda worried me. Then someone else said it's normal, so I'm all confused.
ALSO, it's hot as heck here in south georgia. The pool water itself has been 94 degrees more days! The pool is in direct sun all day long and it's very humid, also it's been raining EVERY SINGLE STINKING DAY OF THE MONTH. Not even kidding. I'm very particular about keeping filters clean, backwashing (once a week or two) and brushing the walls, I'm definitely taking care of my pool the best I can, the water "looks" great, but... it is actually great looking at the test results?
I did not test calcium hardness cause the forums told me vinyl pools don't need calcium eventhough the pool store said it does
TIA!
FC: 2.25
CC: 1
CH: 275
TA: 140
CYA: 45
Salt: 3200
FC: 4
CC: 0
TA: 140
CYA: 35
Salt: 2500
TIA!
