medvampire said:
Just my opinion.
I would drop the CYA and/or raise the FC a little..l run my CYA around 30 and my FC around 4 to 6. I run my pH 7.2 to 7.6 and my ALK around 90 to 120. CC should always be 0. I have a CH problem so it runs around 350 but I have a AGP so its not a problem unless I allow the pH above 7.6.
They are very close.
BTW dont let them sell you things at pool school get your info here. The folks here will help you keep a great pool at very reduced cost.
Steve
These numbers are fine for a manually chlorinated pool but NOT one with a SWG.
Run the CYA in the manufacturer's recommended range and toward the higher end of it.
Run the FC no lower than about 3 ppm up to about 5 ppm
Run the pH at 7.6 PERIOD! (If you try and run it lower you wil have more of an acid demand to maintain the pH. If you run it higher you run the risk of creating scaling conditions and lowering your generators output.
Run your TA between 70-90 ppm for best pH stability and lowest acid demand.
Run the Calcium Harness around 300 for a plaster pool. For fiberglass you can run it a bit lower (maybe 200-250). for vinyl you can go as low as 150 ppm but some 'experts' seem to feel that higher calcium levels can help with pH stability.
Keep your salt to the higher end of the recommended range. This will increase the useful life of your salt cell.
Finally, I would recommend running a 30-50 ppm borate level. This will help increase pH stability, decrease sanitizer demand (and therefore lengthen the effective life of your salt cell), have algaestatic properties, and make the water 'softer'. You can do this with such products as "Supreme", "Optimizer", or "Endure" which are all just expensive borax (sodium tetraborate) or you can use the 20 mule team stuff in the green box from the laundry aisle in the grocery store which is also sodium tetraborate! (Just like you can buy expensive "total alkalinity increaser which is sodium bicarbonate (aka sodium hydrogen carbonate) or you can use baking soda which is also sodium bicarbonate!)
Finally, you DON"T NEED SPECIAL POOL SALT OR PROPRIETARY "MINERAL MIXES"
FOR YOUR SWG! You can use plain (no additives) solar salt or water softener pellets that are at least 99.5% pure and will cost half the price or less!
Combined chlorine in ANY pool should be 0 ppm (under .5 ppm is acceptable). In a pool with a properly set up SWG you will rairely encounter CC!
Hope this is helpful.
