Autopilot Low Amp Cell warning- erratic voltage readings- problem fixed ???
After speaking with Josh I went inside the unit to send him some pictures. Several times I tried re-seating the various connectors that go to the boards and readings were still all over the place. Finally after working with the connectors suddenly it started working. I hope it stays good for the summer- HA........... I hope you work out your stuff Rufus.
Oh- one fan is not working so I will be looking for a replacement fan and SOLDERING it in line. Thanks again to Josh from SaltPoolGuys.com
