First post - I’m a first time pool owner as of a month ago. I found a thread where this Q was asked but not really answered so I’m asking again.
www.troublefreepool.com
I have the same scenario where I’d like to add an actuator with automation to an existing valve in order to direct the suction 100% from my in-wall cleaner port for a couple of hours a day and then have it switch to skimmer suction for the rest of the day. But I also worry what would happen if someone takes out the cleaner hose from the in-wall suction port and the spring-actuated flap closes, depriving the pump of water.
Suggestions?
Installing Valve Actuator between wall suction and skimmer/main drain
I inherited this pool when I bought my house. It looks like the pool returns splits off into wall suction and skimmer/main drain. I believe the skimmer and main drain share the same return pipe. There is a valve that lets me manually control the amount of flow that is split from the wall...
Suggestions?
