- Nov 12, 2017
- 12,679
- Plaster
- Pentair Intellichlor IC-40
Would the air gap that is built into the Pentair T40 with the Fluidmaster valve cover the backflow prevention needs? This is also assuming that the overflow is properly installed.
No, though it is a part of a good BFP system. A first line of defense. It’s missing two key components of a proper BFP. The bottom of it needs to be some number of inches above the highest level the pool water could ever get to, 6” to 18” depending on local code. Strike one. And it needs to be testable, and tested regularly. Strike two. The plastic those types of valves are made of are not really conducive to long-term reliable BFP...
