Are there any pool barriers available to create Isolated areas of pool water
May 24, 2017
22
Roseville,CA
Hi,
I am beginning to see traces of algae in my pool. There is only a small amounts on a few pool walls. Problem is that it comes back Whenever I wipe it off. In the past when this happened only in the spa(Which is connected to the pool)I was able to super concentrated the spa only And get away without having to reach Alagecidal concentrations for the whole pool. I was wondering are there any water barriers that I can buy that I can set up in the pool to create isolated areas of pool water close to the wall where the algae is growing.
If you have algae growing, you need to treat the whole pool. I see you have a good test kit. Can you test your pool and post your numbers?
You may be able to find some barriers, buy why? Any cost for these band-aids with surely be more expensive and more difficult than the true remedy. Your pool and spa should always be at sterile levels of chlorine. Anything less is a recipe for algae and bacteria/viral contamination. SLAM that pool and keep FC per the FC/CYA chart.
