AQUARITE SWG NOT GENERATING. -- Amps are 0
GHAND
13
sarasota, fl
My salt Cell is about 4 months old.
I had my water tested yesterday and the salt is ~3500 but Chorine was below 1
My Cell was cleaned yesterday as it did have some calcium deposits
My system is showing "NOT GENERATING" and the CHECK SALT CELL light is on.
Salt reading is 200
Temp is 87
Voltage is 32.1
Amps 0.00
Output is 100P
Instant Read -200
r 1.59
I have tried resetting
Any ideas? Could there be a fuse issue?
Thanks in advance
G
This is the basic information we need to know in diagnosing a problem:
  • Report all readings when you..
    • Move the switch from auto to off and check all of the readings.
    • Move the switch back to auto and recheck the readings.
    • Move the switch to off for a minute and then back to auto and recheck the readings.
  • What are the first seven characters of the cell and box serial numbers?
  • What is the actual salinity and how are you measuring it?
Give us 3 sets of readings plus the above information.
Salt reading is 200
Temp is 87
Voltage is 32.1
Amps 0.00
Output is 100P
Instant Read -200
r 1.59
Thanks in advance
G
Could be the thermistor. Take the front cover off and it is a large black wafer the size of a quarter located on the upper right side of the main circuit board. If it looks like it is flaking apart, it might be bad. The part is cheap and if you have any soldering skills, it is an easy fix.Capture.JPG
