I am having problems with both my Hayward AquaRite 940 Chlorinators which are 2 years 4 months old. From the installation of these chlorinators I have needed to clean them every 2 months or so. However for the last 6 months the cleaning frequency has increased regularly, so much so that for the last 3 months or so I need to clean them weekly because the salt readings drop by 100 ppm every day or every other day. I clean the cells thoroughly but after cleaning the readings are the same as my digital tester but fall from 3,200 to 2,700 in around 7 days so the process begins again. This is now unacceptable and very inconvenient.
I have adjusted the output from 50% all the way up to 100% but the same problem exists, all that happens is that the readings fall quicker with a higher output setting. I had Astral Pool Clorinators previously and they gave me no problems, the cells lasted 6&7 years before replacing. I do hope you can help? Thank You.
